Continued on panel details. Added labels for Westach, Digitrak and fuel shut off. Made a bracket to support the rear of the radio. Added a switch for the radio backlight. Rebuilt the LED panel light dimmer to fit behind the panel. Checked the dimmer for correct operation. Installed the remaining instruments in the panel with screws I painted gray yesterday. Added a hole to the right end of the panel for the transponder antenna cable and other wiring to the aft of the aircraft.
